creecer
I have to think Jeep might have suspected I might add bigger tires when they built the Rubicon. Upgrades to make it for hard offroad use without thinking larger tires might be involved is unlikely.
A hyrdoboost would be placed in the same spot as a vacuum boost. So the odds of leaking into the cabin is low. Brake fluid is more likely to do that.
Do they at least offer it as an option on those house sized 1 ton pickups? They keep bragging about tow capacity numbers going up every year. The hydroboost would be ideal for them. Plus adding a component on the front of their diesel engines just to produce usable vacuum would save $$. The amount of h.p. vacuum brakes saves compared to the load put on the engine by adding a port on the power steering system would be (in my little brain) minimal. I would think the OEMs would jump on the idea to offer such an upgrade. Adding 10 more cup holders is getting ridiculous.
Lots of large trucks use hydroboost. Ford has been using it on the diesels since 99. I'm sure it serves the purpose of better braking as well as no longer needing to run a separate vacuum pump.
Cost has to be the biggest driving factor, as well as simplicity. A vacuum booster is cheap and only needs one line. The hydraulic lines, routing, and modified PS pump probably aren't worth the cost.
