Yup, just did this a week ago. If you don't want to retain your plastic trim you can just bolt the older style frame in place. The visors are different, but you could make the ones you have now work, though there will be extra holes in the frame so I'd try to source the earlier ones.
Now, if you want to use your plastic trim, which you may want to do especially if you have the auto-dim/compass mirror to hide the wiring, there is more work to do.
1) You need to cut seven (If i recall correctly) slots into the frame. I did this by drilling a bunch of holes in a row and cleaning up with a dremel. These are for the molding clips. You'll see em when you take the modling off.
2) You will need to drill new holes for your current style sun visors.
3) You will need to drill new holes (at least the upper 2) for the side trim screws
4) If you don't change the windshield tie down loop, it will be hidden under your plastic trim and will look funny, so you should grind that off and re-rivet that on as well
Other than that, everything else just bolted right up. Note that you'll want to use heat to get those screws out of your old windshield frame. Edited to clarify: The heat will be required on the screws that mount the frame to the hinges.
