So I had the red brakelight on the dash and saw I was low on brake fluid, read upp on what to do, fill up the system, bleed the system.
Started according to the instructions with back passenger, got some air out and everything looked good.
Moved over to drivers back open up the nipple and got just fluid=good, then when I tighten the nipple thing the threding came loose and all of a sudden the nipple wont close = if I will break all fluid will come out.
So now I need to figure out what part is the part that I need, I saw in a manual that it might be the part that I attached a image for but I am not sure.
Anyone out there that can guide me on what part I need ?
My jeep is a 97 TJ with a 4 cylinder.
Thank you all!
Regards
Magnus
Thank you all!
Regards
Magnus
