As title states, experiencing p0700 p0740 codes after replacing the PCM with one from @Wranglerfix. 97000 miles
This did fix my hard shift from 1-2 that I was experiencing. Also fixed my occasional sluggish start from stop (feeling like I was in second gear).
Checked fluid few times and its full. (suppose it could be quarter to half a quart over).
Few months ago, to make a long story short, I dumped all my tranny fluid through one of the hoses leading to the radiator. It went into limp mode and i called the lady to pick me up and get some atf4 to refill it.
No problem, patch up the hose.
Then drove it 400 miles to Sacramento with no issues. Spent a few weeks there, and then on the way back approx. 175 miles or so i get a p0700 that i check with the key trick. I keep driving and it turns off shortly after and doesn't reappear until a few weeks after finishing the trip.
After developing (or noticing for the first time) some driveability issues I check the reader again and have a p0740 in addition to the p0700.
I did some of research and decided to just buy and replace the computer since messing with the transmission myself isn't quite feasible.
It fixed my driveability concerns, ie the hard shift and less than ideal start from stop.
I read p0740 is the TCC malfunction. I'm no expert on transmission but converter seems to lock up. However I suppose I am not sure if I am not noticing a slip or if I would know what the symptoms would be besides slipping.
The research I have done makes it seem like since the codes are still hanging around its likely the converter is on the way out.
I realize I will probably have to take it to a transmission shop to know for sure but, does it seem likely a rebuild is in the future?
