I'm trying to remove my seats to replace my carpet but they wont tumble forward, which doesn't allow me to access the seat bolts on the back. Help me..
Reach under the seat and feel around for a lever pad. Push down down on the pad and pull up on the back of the seat. It will tumble....then shove the seat adjustment bar down and the seat will move forward. Easy when you get the hang of it.....good luck
Yes, I'd say that's normal. My seats operate the same way. I have a '98.Is it normal for the two seats to operate differently? On the passenger side, when I lift the lever, it tumbles (lifts up and forward) and slides all the way forward all at once. On the driver side, it tumbles, but does not slide forward until I grab the bar on the front of the seat.
Let us know if you have trouble finding the lever pad. I can post a picture later if you need it.I am having the same issue. Both seats won't tumble forward. Thank you for this advice, I will have to try it.
That would be awesome! I am a visual learner. Thank you.Let us know if you have trouble finding the lever pad. I can post a picture later if you need it.
I'm the same way, .That would be awesome! I am a visual learner. Thank you.
I must be blind, I don't see any pads?Here are the photos with the lever pads highlighted with my telescoping magnet.
Drivers sideView attachment 245636
Passenger side
I think the fold and tumble seats were a factory option, do you have the pull loops on the upper part of the seat? My driver side doesn't have the fold and tumble but my passenger side doesI must be blind, I don't see any pads?
Andy-WhiteTJ - I'm new here and I sure there is a happy ending to your profile picture...at least I hope so.I find it interesting that the OP never came back to respond and only has one post!
My passenger side has it, but I can't find the lever on the drivers side? I just looked.I think the fold and tumble seats were a factory option, do you have the pull loops on the upper part of the seat? My driver side doesn't have the fold and tumble but my driver side does
