It looks to me as though that whole bumper deflected.I used to have a swing out style, that lasted about 6 months. Look how bad it deflected.
the bumper did for sure, I wish I would have taken pics of where it bolted to the frame, it was twisted like tin foil.It looks to me as though that whole bumper deflected.
Hack fabrication 101...Surface welded means that the spindle was set on top of the bumper tube and then weld was run around it. The correct way is to put a hole down through the tube so you can weld the spindle top and bottom.
Holy cow man, no snubbers touching and that thing is like 3 feet off the back of the tailgate... I don't imagine your tailgate and tub will appreciate that for much longer...I use the rugged ridge carrier, been a little over a year w/ no issues.View attachment 273305
Doing things properly is rarely the cheapest option. I switched to the Exogate on my LJ b/c I wanted 1) easiest handling experience for my wife or kids (one hand to open, one hand to close!) and 2) wanted the least obtrusive carrier (within reason).Looks like Exogate is $400 these days, plus another $70 to get the rugged ridge tire mount. Kinda spendy for what it is, but I've not ruled it out. My biggest concern is ruining my tailgate if I make contact, but other than that I like it.
I see in another thread DirtWorks is recommended. I could get a bumper/carrier combo for a similar price and the guy estimated it's about 80 pounds for the combo, which seems pretty light, so that could be another good option.
The Morryde kit is ~$300 free shipping at Walmart.com or Target.com and you don't want that RR tire mount as the tire mounting surface is 12" out from the tailgate. Hyline sells a mount with the surface ~7" out from the tailgate like the OEM mount.Looks like Exogate is $400 these days, plus another $70 to get the rugged ridge tire mount.
It’s not even a matter of if, its a matter of when. No way that’s going to last much longer with the tire all the way out there.Holy cow man, no snubbers touching and that this is like 3 feet off the back of the tailgate... I don't imagine your tailgate and tub will appreciate that for much longer...
Check out discountbandit.com I think it's about $310 that way. That's how I purchased mine. I also have the rugged ridge tire mount.Looks like Exogate is $400 these days, plus another $70 to get the rugged ridge tire mount. Kinda spendy for what it is, but I've not ruled it out. My biggest concern is ruining my tailgate if I make contact, but other than that I like it.
Never seen/heard of that one before but it looks pretty nice.My TJ had this carrier mounted when I bought it and it is very sturdy and is holding up since 2012 at least
It is a rear bumper with carrier from Expedition One. It opens with the tail gate. Convenient and easy. No noise and it hold the 35" wheel in place with almost no vibrations
Ok so I ran home to check...look what I found.It’s not even a matter of if, its a matter of when. No way that’s going to last much longer with the tire all the way out there.
Yep, that was going to happen at some point. If that tire isn’t snug tight against the body it’s going to result in this. Like I said, it’s not if, it’s when.
my thinking: the mount, like the tailgate/hinges/tub, was designed to hold a 30.5"x9.65" tire at best. YMMVWhy wouldn’t you just use the stock tire mount with the MorRyde?
The MORRYDE uses a bracket to tie the upper hinge into the cage which takes quite a bit of load off of the tub at the upper hinge. So it’s a better way to go as I see it.Well I wish I would have checked here prior to buying...live and learn. So is MorRyde the way to go?
Might depend on the bumper you have but most people installing a 35” on the MorRyde/Exogate will have issues with the tire hitting the bumper unless it’s relocated upwards. The exogate includes brackets to raise the tire upwards but those brackets also move the tire out like 2” further away from the tailgate which then takes lots of snubbing to secure the tire. Hence why a popular solution here is to rework the stock carrier to raise it up while keeping the same distance from tailgate which can be snubbed easily unlike when the tire is mounted 2” further out with the lift brackets.Why wouldn’t you just use the stock tire mount with the MorRyde? That’s what I did with mine. Didn’t even need to use the bracket to raise it (might need bracket if no body lift) and 35 fits fine.
