I've been taught three pretty valuable piece of trivia about life and the world around us:
1) A former federal prosecutor and constitutional lawyer whose blog I enjoy taught me that almost any lawsuit that claims RICO violations is not RICO.
2) Gregory House MD taught me that it's almost never Lupus.
3) Anybody who actually knows what they're talking in regards to Jeeps about knows that a steering stabilizer doesn't cure DW.
Kind of a corollary to #3 is that if you have to ask if what you experienced was death wobble, then it wasn't death wobble. The poop in your pants will tell you if it was DW.
That being said, a serious vibration in the front end is almost universally caused by two things: loose components or unbalanced tires. Anything else is a freak statistical outlier.
So the general recommendation is to first get under your front end and make sure everything is tight. Get somebody to turn the wheel while you're under there and look for components that shift or make a noise that they're not supposed to. Look up torque settings and confirm that all of your bolts and nuts conform. This is, by far, the cheapest test, since it costs you nothing but your time.
If it's not anything loose, THEN you take it to a tire place and have the balance (and perhaps alignment) tested. If you have anything larger than a 0" lift and stock tires, do yourself a favor and do your research ahead of time, and make sure that the shop you go to makes it their business to know how to deal with larger wheels. No knock on Tires Plus or Mavis or your local tire place of choice, but a lot of them just don't deal with them as much as a 4x4 place might, and may not have the expertise or equipment to, for example, test the alignment of a large tire at speed.
