The 210 marker on the gauge is effectively a dummy guage. It's anywhere between ~190°F and ~230°F when showing "210".
It's possible your thermostat is like my original was last year. It was opening at 195 as designed, but too much and often staying open as actual temps were running 190°F on the highway. I wasn't overly concerned as failing open won't leave you stranded.
While doing the SPAL 850W fan mod and Edelbrock head swap, I changed to a Robert Shaw 330-195. It now opens at 195 as before, but controls opening and holds the temp higher as designed. I log 201°-208° and occassionally up to 221° when climbing up extended grades on I-70 into the CO mountains. All of that is normal and the gauge touches the 1 in 210 the whole time.
