05 TJ transfercase rubber isolation bolt size
CONJOB
South Carolina
Hi
I am installing the Genright crossmember in my 05 LJ. I attempted to install the new crossmember when I saw that the crossmember was hitting the front driveshaft. I have some spacers to go into position. i need longer bolts but I did not get the size before I reinstalled the rubber isolation plate that goes between the TC and the skid plate.
Does anyone remember what size the bolt is to attach the rubber isolation plate to ther TC?
Thanks in Advance
Thanks Charles,
I looked and searched but I could not find this PDF.
Scott
Thanks Charles,
Scott
Its the 3rd STICKY in the TJ Resources section.
Then search for your year Parts List.
On the '06 it is diagram 9-130 and on the '05 it is diagram 9-120.
Jeep Wrangler TJ Factory Service Manuals (FSM) & Technical Documentation​
Reactions: Spike Strip
