My lines finally corroded enough to spring a pin leak, smoking up the engine bay and lubing the control arms below.
I ordered a SS replacement set from Lines To Go, thinking their set will help me avoid any other disassembly to replace both of the quick connect lines, radiator to trans.
Anyone have any experience with replacement on the 06 LJ? Is this likely a couple hour job or more?
