The PCM was replaced on my daughters 06 wrangler in December 1017. They also replaced the ignition clutch relay switch (I think that's what it is called). About 2 months ago the horn stopped working, then the a/c, next the interior lights quit, the dash has multiple lights showing ( check engine, check guages, no fuse, emergency brake, and 4wd). And you can start the jeep without pressing the clutch again. We have checked all fuses and relays. The emergency brake is not on and it is not in 4wd. The a/c checked out good. The battery is good. Could the new computer be going bad and causing all these unrelated issues?
