Hey all, I've got a 2006, SE, 6-speed manual with 70,000 miles. I had a small radiator leak that I finally got around to fixing back in August. It took me a while to make the repair because I was searching for an OEM radiator. I eventually gave in and bought one from NAPA. Long story short, the petcock valve failed and my wife drove home from work with no coolant and the jeep stalled at the end of our driveway. When I got there, there was oil everywhere (it is covering every inch of the under-carriage). Upon closer inspection, I found the failed petcock, practically zero coolant, and the engine took 3 quarts to get back up on the dipstick. After making sure the engine was not seized, I topped off the oil, and after cranking for about 30 seconds, it fired right up and sounds fine. After some convincing, I got NAPA to honor their warranty and get me a replacement radiator (somehow I didn't lose my S**T, but I live in a small town so I was cordial). *If this engine pulls through I will get a better radiator* After topping off the coolant I did a combustion gas test on the radiator and confirmed the presence of combustion gasses. We live in a small mountain town 2 hours away from anything, so this Jeep does not go far from home. It's my wife's daily driver, but her commute is about 8 miles roundtrip. Otherwise we pop into the mountains with it or take it around town. The jeep is in great shape otherwise and I would like to keep it going, so I am considering my options. In either case, I would do all of the work myself. Option 1-Replace the head gasket and inspect the head and have it replaced or resurfaced as necessary, I would also doing the timing belt at the same time. Option 2-find a decent used TDI engine and necessary components and do a diesel swap.
I would be perfectly happy just doing the head gasket if I thought that would get me back on the road, but I'm concerned that their could be other issues. Where did all of the oil come out of (hard to tell as everything got soaked). What kind of shape are the piston rings and bearings in now? Could the rear main seal be blown? It has held 5.5 quarts just fine over the last week and has ran about 30 mins and got up to operating temp multiple times.
As for the diesel conversion, it would be the more expensive option and I never really had a problem with the 4cyl power, it's got 30" 10ply tires and gets around just fine. I wouldn't mind lifting it in the future and bumping up the tire size a bit, but its got a Dana 35 in the rear and I wouldn't want to push it. Having said that, I would actually feel good about the scenario if I made it to the other side of all of this with a diesel swapped TJ (assuming it was reliable)
Any recommendations or thoughts on my predicament (other than parking it through the plate glass window at NAPA)
Thank you
Thank you
