New member here checking in from Texas, my TJ with 104,000 has some issues that I need some help with. This all started when we where driving it would suddenly die and loose all power and would not start back up at this point it kept blowing the ASD fuse under the hood. I traced all of this back to the a few breaks in the wiring to the dreaded stud behind the valve cover and fixed all of that and still the same issue, once the jeep gets up to around 205 it will shut off and will not start back up until cooling off. At this point I replaced the crank position sensor and cam position sensor and still nothing. I went ahead then and replaced the ECM with a new one and the issue is still there. At this point I gave up on it and put it in the shop for them to trouble shoot....they ohmed out all of the wires and couldn't find anything and now they are at a loss. The Jeep is throwing a P0161 and P0121 codes currently but it hasn't always thrown these coded. The Jeep also has a new alternator on it. It will start and run fine when cold until it gets up to 205 or so and then it shuts off.
Could the issue be with a MAP sensor and the signal to the computer to go from open to closed loop? Any idea what to look at next? I'm tired of loading the parts gun and firing blindly at this thing and need my Jeep back! We have also tried unplugging the temperature sensor and no change. The crank and cam sensors where replaced with OEM Mopar sensors.
Help and thanks everyone!
