Minnesota 2004 Jeep Wrangler Unlimited
Grenadiers
St. Paul, MN
Price
22,000
Minnesota
Selling my 2004 LJ. Has the following:
104,000miles.
Auto transmission. Sport model, no cruise control. Raised engine mounts.
Raised throttle body. Air raid filter intake.
New AGM battery. Dual ARB air compressor, hose out front. Great A/C and heat.
IMG_7429.webpAftermarket stereo w/cd, and amp.
Both hard and soft tops. JK front headlights. Warn XD9000i winch, like new. Warn front bumper.
35” BF Goodrich KM3. 4.88 gears. Crown ZJ tie rod and drag link.
Set up for high steer steering. Teraflex
Knuckle on passenger side.
Currie front Anti-Rock sway bar.
Rubicon Express long arm in front,
Short arm in back. Great flex.
Several bushings replaced recently.
RE front and rear adjustable trac bars.
Atlas II 3.8. Currie HP Dana 44 in front with Yukon air locker. Stock rear axle and locker.
Newer rear Black Magic brake pads, and Centric rotors. Swing out tire carrier.
Rock sliders. 1.5” body lift, 4” suspension lift. Fuel tank skid plate.
Rear differential cover skid plate.
Power steering gear skid plate.
Rear bumper has a hitch.
Hand held CB, with whip antenna.
Frame painted with Por-15 top coat. Entire
Frame soaked with Fluid Film.
Axles painted with POR-15 and top coat.
Body and frame are rust free. Arizona Jeep.
In Minnesota now. Derale tranny cooler.
CV joints on both driveshafts. Recently greased. Banks muffler.
No squeaks in suspension or exhaust system. Dorman tranny pan. $25,000.
Have all of the paperwork for its build. Minus the suspension. Has a small RMS leak. Engine is very smooth running. Hi-Lift jack. Clean title. Cash or bank check. IMG_7428.webpIMG_7425.webpIMG_7426.webpIMG_7427.webpIMG_7422.webpIMG_7423.webpIMG_7424.webpIMG_7421.webpIMG_7419.webpIMG_7415.webpIMG_7416.webpIMG_7412.webpIMG_7413.webpIMG_7414.webpIMG_7411.webpIMG_7410.webpIMG_7409.webpIMG_7406.webpIMG_7407.webpIMG_7403.webpIMG_7404.webpIMG_7400.webpIMG_7398.webpIMG_7396.webpIMG_7393.webp
