Hi again Everyone, this is a follow up to my original post. Our 2004 Rubicon with 152,000 miles is ready for some light trail duty now. We don't plan to do anything other than the easy trails (no rock crawling, deep water crossings, or situations that would lead to tip overs). We just want to join the Reading PA off road park and enjoy the outdoors with this Jeep. It is completely stock and is pretty solid. It has new tires (Sumitomo Encounter AT which are fairly aggressive but not a mud tire). I purchased new Moog springs front and rear, 5/8 inch isolators (spacers) for the front and rear for a little extra lift, and Rancho RS5000X shocks that will accomodate up to a 1 inch lift. I also have the quick disconnect pins for the front stabilizer so we can get more articulation out of the front end if necessary.
My question is will the 30.5 inch tires contact the stock fender flares with the stabilizer disconnected if the front end is in an extremely articulated position? If so, would wider fender flares be the best way to go considering that I don't want to go too radical with this Jeep? And, the front spring already has one isolator installed so should I install two to maintain the correct body geometry?
Because I am new to wheelin', your experienced opinions will be appreciated.
