SOLD SOLD SOLD SOLD 2005 Jeep LJ
LukesfirstJeep
Central PA
Price
14000
Lock Haven PA
For Sale 2005 Jeep Wrangler TJ Unlimited $15,000
I’m selling my 2005 Jeep Wrangler LJ. I've owned this Jeep for about 6 years. It is equipped with both hard and soft tops, 4.0L 6 cylinder engine, automatic transmission, power steering and brakes, AC, cruise, and intermittent wipers. It has almost 123K miles.
It has a 3” lift with Ranch shocks, and 33” tires. The drive train has been properly upgraded, including regearing the axles to 4.88. It has many upgrades and I’m sure I’ve forgotten a few (see details below).
This Jeep is not perfect, but it is solid. When I first bought this Jeep, I spent a lot of time cleaning and preserving the frame, both internally and externally. I applied at least 6 cans of Eastwoods frame sealer internally, after cleaning and flushing.
I’ve had many adventures with this Jeep and had fun building it up to its current state, but it’s time to move on.
Modifications/Upgrades
Exterior
Soft top and mounting hardware with window storage bag.
Bushwacker Flat fender flares
Rock sliders with side step
Custom bumpers fabricated by James Kinney
Frame/rear bumper tie-in brackets
H4 Toyota headlights with HD wiring and relay
LED fog lights
Suspension/Drive Train
3” Zone suspension lift
33” tires (285/70-17)
17” wheels with TJ pattern Black Rock Viper Series 900 in Tungsten
Rancho 5000X shocks
Regeared axles to 4.88
Advanced Adapters slip yoke eliminator (SYE) with double cardon driveshaft
Adams driveshafts front and rear
Savvy adjustable upper rear control arms
JKS front & rear lower control arms
JKS adjustable front track bar
Rear track bar relocation bracket
Front Sway bar quick disconnects
Lubelocker reusable differential gaskets
Moog polyurethane bushings front sway bar
Set front and rear pinion angles and centered axles
Savvy transfer case cable shifter
Interior
Bestop seat covers front & rear
Front seat raised with Buchanan Precision Machine brackets
Quadretec floor liners front & rear
Husky cargo liner
Bedrug carpet/floor covering front & rear
Sound deadened tub floor and walls with Siless 80Mil mat
Insulated and sound deaden hardtop with Hot Head liner
Audio
Kenwood Bluetoooth Stereo
Sound Ordanance amp
Polk speakers front & rear
Maintenance Replaced over the past 6 years/20K miles
Replaced front ball joints
Replace front axle U joints
Front & rear diff oil change
Lube Locker differential reusable gaskets
Trans & transfer case oil change
Front diff gasket/seal replacement
Replace rear main seal and oil pan
Replace exhaust header hardware and nut clips
Replace PCM with WranglerFix PCM
Replace transmission oil cooler lines and pan
B&M aux transmission oil cooler
NGK spark plugs
Replaced air filter
Replaced serpentine belt and idler
Replaced valve cover gasket
Replace rear rotors and pads
Replace fuel pump
Frame protection (with gas tank removed) clean interior and exterior surface rust with wire brush, grind, and/or sand blast, wipe it down, coat with Eastwood frame sealer internally and self etching primer, top coat spray paint externally
Replace door hinge bushings
Replace vent cowl seal
Coat undercarriage with Fluid Film
Replace fuel filler tube
Fix gas tank fill valve
Magnaflow Cat Back exhaust
Misc. Extras Included
Soft top with all mounting hardware
Hard top storage rack
Spare front fenders
Spare fender flares front & rear
Wired for flat towing
Blue Ox tow bar brackets installed
Wired to tow with 4 pin socket
Many OEM take off parts
Reactions: JMT
