2006 TJ O2 sensor issue P0161
not sure how it would be showing a duty cycle with the key off but im also out of my element with this issue.
either way, i think im at the end of what i can do. ill probably be sending my pcm off to @Wranglerfix next week and just have them test it.
And you’re not at the end of what you can do. Swap sensors and graph them.
Reactions: Wranglerfix
Report back with results when you get it installed
After a week, no check engine codes. But o2 sensor heater test still showed incomplete. Did the repair listed in the TSB today and finally all my emissions test are showing complete.
Unfortunately I have a new issue, since I installed the replacment pcm my AC compressor won't disengage. Only way to get it to turn off was by pulling the relay. I sent an email to Wranglerfix, he got back with me the same day and has a replacement pcm already shipped out for me.
Reactions: ItchyDong
