Exactly. But when someone says the have a rebuild kit it makes me wonder.Assuming it actually works thats the deal of the century.
Intact viable empty case is worth what he is asking.Exactly. But when someone says the have a rebuild kit it makes me wonder.
I do agree with you as long as the buyer knows what they are getting. It would suck to think you're plug and play only to find out otherwise. I was a happy camper when I got mine for $400 in great working condition many years ago.Intact viable empty case is worth what he is asking.
Check for cracks in the case itself. Make sure it is a TJ case, throw it in 4 low and rotate the input shaft once and make sure the output turns 4 times. You can also drain fluid and check for chunks of metal. Looking at the pics it looks to be correct. Nice to get the rebuild kit with it.I posted it on here then couldn't resist. Checking it out tomorrow. Any advice before looking at it?
Thanks!Check for cracks in the case itself. Make sure it is a TJ case, throw it in 4 low and rotate the input shaft once and make sure the output turns 4 times. You can also drain fluid and check for chunks of metal. Looking at the pics it looks to be correct. Nice to get the rebuild kit with it.
What he means by make sure it is a TJ case is it has to have the output shaft speed sensor.Thanks!
Will do. Thanks!What he means by make sure it is a TJ case is it has to have the output shaft speed sensor.
