The FSM says to tighten the first band before removing the pump to hold everything in place. No problem, an 8mm wrench fits over the square end of the adjuster screw perfectly. Then at the end of the process it says to torque it to 72 in-lbs, and then back it off 2.25 turns. The problem is an 8mm socket does NOT fit over the adjuster screw. In fact no socket fits on the screw suitably. The wrench fits because it's square, the socket needs it to be hex shaped, obviously.
Ultimately w/o a socket I have no way to use my torque wrench, unless there's some old school way I'm not aware of. My next best option is to get an 8mm Crowfoot to put on the torque wrench, but that technically changes the amount of torque applied since the lever arm is slightly longer. I guess I can do some math to figure out what the actual torque is and set the wrench accordingly, but just having the right socket seems way more reliable of a method.
Any ideas?
Any ideas?
