32RH Torque Converter Lockup Solenoid
jarrett_jj
Colorado
Hello, after seeing several members tackle 32RH rebuilds I followed suit. 5w20 will work in a 32RH to get you home, ask me how I know. During the tear down I noticed my lockup solenoid is in bad order. PO or shop apparently melted the connector from the inside of the case to the through case connector as well as the wires being bare in some spots and wire insulation cracking everywhere.
While trying to find a new solenoid I found a direct replacement for mine but cannot find through case connector part. I also found a solenoid with a different through case connector from Rostra # 520507. Does anyone have experience with this solenoid working or where to find the through case connector.
