I have not outboarded the shocks yet. I did use the Clayton rear lower shock mounts. It moves the location further out and reinforces the rear bottom link brackets.On the rear, did you use Clayton’s shock mounts or more of the generic Poly/genright style when you outboarded? The Clayton kit looks better than most the ‘kits’, there’s just a few things I’d maybe go my own way on
I Just purchased the poly performance out board kit and plan to cut into the frame. When I do, I may reuse the clayton, but cut and rotate part of it to line up the lower mount since it will not need to have the inward tilt it has now. Or I will keep the bracket reinforcement, but “glom” on the poly mounts to the bracket reinforcement. The poly mount retaining bolt is front to back versus side to side. May compress the bushing less during articulation. We will see
