97-06 TJ/ LJ Warn Winch Plate
Ashton Keiffer
Lexington, SC, USA
Price
75
Lexington, SC
Warn winch plate for a 97-06 TJ or 03-06 LJ. $75 O.B.O.
Anyone know anything about this plate? Would it allow me to mount a Warn 8274 winch on my Mopar Rockcrawler bumper? the Warn manual for this plate says "Compatible with Standard Bumper or Mopar Accessory Tube Bumper." Not sure if the Tube bumper is the same as the Rockcrawler?
This will not work with an M8274 however I do have an adapter bracket for one that I have not listed yet.
I still have it, it will work as long as there isn't anything mounted between the bolts that hold the bumper to the frame rails
Hate to waist your time as shipping to St. Louis would probably double the price but would the bolts be to short then? Couldnt you use longer bolts?
I could have worded that better, when I said between the bolts I ment in the space between the frame rails where the winch plate would sit. If you have any other brackets they might get in the way. The factory bumper bolts are long enough to mount the winch plate with.
Reactions: Sam Solo
