I have a 1998 4.0, Automatic that needs all harnesses (engine, dash, rear body) replaced (they're completely and totally chewed through by rats). I know the obvious answer is to replace all three with identical harnesses, but I'm having trouble finding the engine harness in particular.
Mopar support told me I need the following part numbers:
- Engine: 56041443AA
- Dash: 56010350AB
- Rear Body: 56010164AD
Does anyone know what other engine harnesses might be compatible for me? I found this one below on ebay, but the part number 56010285AD seems to indicate it's for a manual.
Jeep Wrangler TJ 97-98 4.0L Standard AUTO Engine Wire Harness Wiring Loom
Thanks for the help. One note: this won't be a daily driver and will probably be ranch use only. I don't particularly care about ABS and other options.
- Dash: 56010350AB
