98 TJ cigarette lighter fuse location
RyanMkTJ
Oregon
Hey Jeep people,
My cigarette lighter stopped working while using my tire inflator on the trail. Where is the fuse for it? Here’s my fuse box legend, no cigarette lighter fuse listed. Any suggestions?
Just checked the FSM for the 97, it says the fuse for the lighter is 20 in the PDC, which is located in the fuse box under the hood by the air intake.
Thank for looking that up. I have a 98’ not sure if that changes the location. Fuse 20 isn’t blown. I just checked. Maybe it’s a problem with the lighter connection/wiring not the fuse?
I just double checked my FSM, and I misread it. It looks like fuse 5 in the PDC is where you want to look. Sorry for the mistake.
If it's not a fuse I would suggest checking the relay next. I'm not much of an electrical guy so maybe someone else can chime in and give you some more direction.
Reactions: SSTJ
When I was doing my dash wiring I blew the fuse on my 97 for the cigarette wiring. It was under the hood. I forget which, but it was easy to find.
Edit: F5, the new one. Check the under hood fuses.
Reactions: SSTJ
