Ok, I have a new issue... my 2006 LJU automatic, my air conditioning works fine when I am on the highway/street moving. When I stop for more than 5 minute or so such as stopped for a train or waiting for food at a fast food restaurant the vents will start to blow warmer air out of them. They blow warm air just not near as cool as when the jeep is in motion. All my flap settings work fine, my engine coolant temp is rock steady at 210,... I put some gauges on the HIGH/LOW (260psi/41psi@80degrees) so the pressures are in the green for the outside temp range. My radiator mechanical fan seems to be working fine but i does get unbearably hot in the engine bay (might be normal?) Condenser is clear of debris as I power wash it.
any ideas? I tried to find other forums but really most stopped in the middle of the threads with no solutions.
The only thing I can think of, I do have grille inserts and I do feel the radiator fan suction through the inserts... I just dont know if the airflow is sufficient. I will remove them later today and post my result but in the meantime I like to hear what everyone has to say.
Thanks in advance...
