I just went thru this leak chasing procedure. I charged the system with dye and could not find any sign of a leak. The system would be empty in about 5 days. Tried it again, with same results. Inspected the system at night with black light, no leaks found. I was thinking the leak was probably the evaporator also. I recharged the system and borrowed a sniffer from work. I removed the blower motor and fan assembly, and sniffed around in there, no luck. Back up front, I quickly sniffed out the leak at the very top corner of condenser on the passenger side. Even with the condenser removed, there was no sign of the dye. I replaced the condenser. Its been about 3 weeks, and I've still got cold air!
