A/C Help With 2006 LJ
Jharris1983
Freeport, FL
I’ve perused the forum on the topic, lots of same threads with the vents only blowing feet/defrost.
I’ve traced vacuum lines and even pulled the control panel to make sure the previous owner didn’t somehow unplug a line when they installed the radio.
I can see the actuators under the driver side and behind the glove box move as I select. However, the air flow simply doesn’t change.
None of the little attachment arms are broken off and they seem to open and close completely without any hesitation or clicking.
I’m thinking it has to be the door itself not moving inside.
Which actuator actually controls moving the air to main vents? Any idea what the part number is for the door?
I know this is a common topic but I’ve tried everything suggested.
Jeep is new to me but hasn’t been molested at all.
You can look up the P/N in the parts book under Resources. The FSM is there as well.
Haven't had this issue with mine yet, so I haven't researched it.
Where is the resource section for the manual? I’m on my phone so maybe better to use the laptop. I don’t see it in the menus.
