New here! Just bought my Wrangler and it seems to be a common issue. The check engine light is on throwing the code for the sensor. I've taken it to the mechanic they try to put an aftermarket sensor on it they rejected it and they recommended only Mopar. Problem is those are all discontinued online everywhere you look! So my question is what have you all used out there as an aftermarket sensor that has or hasn't worked successfully?
