I'm a newly registered user but haveused the forums for many years). Anyway....
I have these codes on my 2001 TJ 2.5 and would like some advice.
P0441 (EVAP purge flow monitor-insuff. or excess. flow detectected)
P0442 (Monitor med. leak detected-a small has been det. in EVAP)
P0443 (EVAP purge solenoid circuit-an opened or shorted condition det.)
P0455 (Monitor Large Leak Det. In EVAP sys.)
P0456 (Monitor Small Leak detected in fuel unit)
What is different is that a t amount of gas vapor rushes out of the gas fill inlet when I remove the gas cap even if it is on for just half a day. I had it smoke tested and no leak was found. I replaced the purge valve and solenoid (perhaps bad?). The leak codes don't make sense to me sense vapor is blowing out in such a rush ( I don't even secure the gas cap completely because I don't won't to put uneeded pressure on the tank or EVAP system, or have a Jeep bomb) If it's not that what else could be blocking it? Any one solve a similar issue? Ideas? Thanks in advance.
