Is that the wrong wheel size?It's interesting that every time I see a set of these they're on 10" wheels.
Road warriors or very amateur wheelers a lot of the time.It's interesting that every time I see a set of these they're on 10" wheels.
Like me apparentlyRoad warriors or very amateur wheelers a lot of the time.
I would say you’ve graduated from the “very amateur” categoryLike me apparently
Ohhh well thanks. Except for when it comes to wheel sizes, thenI would say you’ve graduated from the “very amateur” category
My experience with a 10" wheel wasn't a good one. Depending on the terrain, I will air a non-beadlock wheel down to 8-10 psi. On 8 - 9" wheels I've never had a problem. I ran a set of 35x12.50R15 MTRs on a 10" wheel, at the same pressure, and lost a bead. That only happened once, but in combination with the way the Jeep tracked on the road, and looks, that was enough for me not to like them. To be fair, I've known others who have run them with no issues.Is that the wrong wheel size?
It’s not the wrong one per say, I would go with an 8-8.5” to give a little more sidewall bulge and tuck the lip in a little more. 10” would be more likely to burp before than 8” if you are aided down low off road.Is that the wrong wheel size?
Aha I see that does make sense. Thanks guys. Now I'm officially not an amateurIt’s not the wrong one per say, I would go with an 8-8.5” to give a little more sidewall bulge and tuck the lip in a little more. 10” would be more likely to burp before than 8” if you are aided down low off road.
