Which one is that?View attachment 29676 I like it, but I think I’m married to this lovely beauty. Took me a while to find it.
Every time i go back and look at pics lol. My next one will surpass that. It’ll be exactly what I want and then some hahaOh snap, @Starrs is taking a trip down memory lane![]()
Won’t be wild. It will be a Long Jeep on 35s and highlined lol if it has a hemi that will be cool but not necessary at this point.Mild or wild?![]()
I have an lj I setup with Arb stuff and nth degree tummy tuck and skids in them late 2000,s. I like it but boy it’s heavy. The original Arb rear tire carrier, it’s a monster, I think mine weights in over 4500 with gas in it
Any idea what the suspension set up is on this?
Day Star 1.25 body and motor mount lift.
Old Man EMU 2.5” lift with shocks heavy load springs.
MORE Steering Riser bracket 1”.
33” Mickey Thompson Baja MTZ.
G2 Dana 44 axles with ARB lockers Front & Rear 4.56 ratio.
Currie CurrectLync Steering.
Hope that helps.![]()
Nice! It does thank you. I’m surprised that it has a body lift. Usually I can tell because the you can see the gap between the body and the bumpers which I do not like. Are you sure about that?
Its very tough to notice a 1.25" body lift. Its a very good modification for our Jeeps, in that it allows you to move things up relative to the frame and improve clearance and breakover (like the center skid and Fuel Tank Skid)
Set it up properly. Ride quality is more about proper setup than the parts you use. Exception to that is shocks. Good shocks aren’t cheap and cheap shocks aren’t good.Good to know. Mine is lifted right now. I bought it like that and have no clue what exactly was done and what was used. Honestly I’m looking to get the best ride quality I can out of a lift. I just ordered the ARB bumpers and sliders. Next will be to get the suspension sorted out. Appreciate the info sir.
You can make it ride pretty damn good though, by making sure your shocks and suspension are centered in their travel at ride height. Don’t run anything over 30 psi in your tires either.
Any recommendations? Do you think this set up is good or maybe go with something else? There’s so much out there I thought this rigs set up might be a good place to start.
