It looks like my issue is two-fold. When I removed the connector from the switch and jumped it I still had the short. I know this for a fact as not only did my in line test lamp indicate a short, I also removed the test light and tried a fuse which blew instantly. When I unplugged the connector under the hood and checked with a DMM the short was gone from the switch side but still present on the load side. Next I pulled the plastic cover along the door jamb by the driver's seat and inspected the bundle. The part that comes down from the kick panel area lays against a corner of metal. I pulled it up and saw some tiny perforations in the plastic covering with bits of wire insulation showing thru. I slit it open and looked everything over but couldn't really see any damage that exposed copper but the short had disappeared when I pulled it out, so I wrapped it in engine harness tape followed by a layer of Scotch 33 and put it all back together, the short was still gone. Keep in mind all this time I had the switch disconnected and jumped. No short and the backup lights worked. Then I plugged the switch back in and I had a short!
Thinking it must be in the harness laying on top of the transmission and shorting when moved, I jumped it again and moved it every which way, no short. Plugged it back in and moved it every which way and the short remained (I'm using a 12 volt incandescent lamp in line to keep from blowing fuses).
Now I know there was a short when I bypassed the switch because I tried a fuse and it blew instantly.
So in light of the fact that this short first appeared intermittently and now all the time it can only be that there was an intermittent short in the wire harness at the door jamb and later the switch went bad making two shorts. It's the only thing I can figure.
At first I was convinced it was the harness on top of the transmission but even when I carefully unplug it without moving the harness and plug in the jumper the short goes away.
So I'm back to needing a switch and can't decide which one to get. I can order Echlin from Napa, or Standard from O"reilly. I also see Crown and Omix. The only one I saw someone here report on was the Standard brand and that was
@AndyG and I believe the only issue he had was a replacement plug not fitting the pins tightly. Any suggestions?
