Finished installing ball joints. Reinstalling the knuckles and I have a small gap between the knuckle and upper ball joint on both sides. I pressed both uppers and lowers until the shoulders were seated against the C arm firmly. I BFHed the knuckle from underneath to get it high as possible but it’s already against the lower ball joint. Will tightening down the bolts to torque specs close the gap? Is it ok for there to be a gap there? Just want to make sure all is good before putting everything back together only to have to take it all apart again. Any input is appreciated. Thanks!
