L Lucky! Member Joined May 2, 2023 Messages 61 Location Boston Aug 24, 2023 #1 belt tensioner snapped when coming off. See pictures, any thoughts?
Jerry Bransford Retired Supporting Member Joined Nov 9, 2015 Messages 29,736 Location Fleming Island FL Aug 24, 2023 #2 Mopar p/n for your 2004's automatic belt tensioner is 4861277 like at https://www.amazon.com/dp/B0015H0V5G/?tag=wranglerorg-20
RMETeeJay TJ Addict Supporting Member Joined Sep 30, 2019 Messages 1,120 Location CO, USA Aug 24, 2023 #3 See if you can carefully chip out the broken piece that stuck. The new part will have 2 nubs that must be inserted into the mount in order to properly tension. If you can come at it from behind, that would likely work best. Reactions: Jerry Bransford
TokenJo Member Supporting Member Joined Jul 11, 2023 Messages 76 Location Western PA Aug 24, 2023 #4 5:00 mark. Pulled the alternator bracket out to do it. It is aluminum, so shouldn't be hard to drill out.
OP L Lucky! Member Joined May 2, 2023 Messages 61 Location Boston Aug 24, 2023 #5 Fantastic response. Worked perfectly. Here’s a pic in case anybody wants to see it. New idler, pulley and belt as well.
OP L Lucky! Member Joined May 2, 2023 Messages 61 Location Boston Aug 24, 2023 #6 Lucky! said: Fantastic response. Worked perfectly. Here’s a pic in case anybody wants to see it. New idler, pulley and belt as well. View attachment 452466 Click to expand... The belt is not on in this picture, but I put it on after taking it Reactions: TokenJo
