So I have a Yamaha ar190 boat and the charging system is not up to the job of supporting a aftermarket stereo system. The problem is I have a alpine pdx v9 amp on the boat and it completely depleates the batteries faster than the boat can recharge them. I in the past have solved this issue by running the boat entirely off one battery. Then I ran the amp off the second battery. I was using solar panels to recharge the battery when the boat was not in use. The issue now Is that I am dry docking the boat at a new marina and do not have access to enough sun lite to keep this battery charged. I was thinking about buying a lithium battery jump pack and using it to support the battery while in use. I found this one. I’m not sure if this will work as a solution to my problem or not.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/142591789144
It’s 4000amps which is more than some others I saw on the market. Idk if u guys had another suggestion or possibly a different jump pack that would work
