2006 Rubicon 55k miles auto trans
Hopefully you guys can give me some good insight about what my solution should be. The problem is this: I purchased an 06 Rubicon with 52k miles on it. PO says everything works, yada yada. I did my own PPI and everything was indeed working. Come a few weeks of ownership I had a caliper sieze up on me. I made sure the slide pins we're okay and the issue went away. I purchased black magic bands and centric rotors and now the issue has returned. It's happened on all calipers at some point over the few months the new pads and rotors have been installed. I'm going to replace the calipers and immediate brake hoses, but would rather not replace the pads and rotors because they weren't cheap. Could the issue be with the lines or would you just pinpoint it to the hoses and/or calipers? It's an an easy fix, just might be more expensive than I want it to be. Any thoughts? Or something I should test first or any questions?
