I need brake pads on my LJR, and whenever I need to service or replace something, I always consider if an upgrade would have any significant benefit or value.
So, since my stock brakes don't to a great job stopping on the road with 33" tires mounted, would it make sense to upgrade to better brakes? My 33" tires are on 15" rims, so I'm thinking a brake kit would probably make it impossible to use the 15" wheels, so I'd have to use the 16" wheels (where my street tires are mounted) or even buy 17" wheels. Of course, if I'm having to use or buy bigger wheels, then I have to sell the small wheels/tires and get new tires, which means I might as well get 35" tires, which is a general goal I have. At that point, I need to re-gear the axles. And, I don't think 35" tires will fit with the rock sliders I have on the sides (protrude into the wheel well a bit), so I would have to replace those too! Oh, and will I need to modify the mild lift too? So, this keeps spiraling down the rabbit hole just because I'm concerned about brakes.
Can any of you put some common sense into my head? I purchased the LJR modified, so I haven't had to do anything to it in my ownership. That inexperience makes me question my ability to make sensible decisions on what's really needed.
Thanks!
Thanks!
