Broken Rear Sway Bar
Bigfoot-NM
Albuquerque
2006 TJ, 3-1/2" lift, 1" body lift, G2 Dana 44 rear axle, 35" tires. Was out 4-wheeling today and broke my rear sway bar. Seeing how I bought this Jeep used, not sure what sway bar was installed.
Any recommendations on a replacement rear sway bar? The sway bar links are still good, so I am assuming I can reuse them.
I not seen a broken rear before, you might consider installing new extended rear sway bar links when you do the new rear sway bar, that may be why it broke. Where is the break, post a picture up. I just installed 3" extended rears in mine for $31. Welcome from a Newer Mexican!
Reactions: Kiwi TJ
The rear links I have are 10" between hole centers. It broke right where the sway bar goes into the bushing mounted on the axle.
Just stuff a stock swaybar in there. The aftermarket ones I have seen all are thicker and probably less flex. Or go Currie if you want.🤑
So I verified that I do indeed have 3" extended rear sway bar links installed on my rig. Stock sway bar links are 7" on center......the ones I have are 10" on center.
Here are pics of the broken sway bar....
Yeah, it was a fun day of trail maintenance and joy riding.
I was also dragging my trailer filling it with the "stacker" rocks to get them away from the gate keepers.
