Budget axle upgrade advise
Cajuncrawler
Louisiana
I have a recent TJ purchase. I bought it knowing the front differential needed work. Apparently it was run without lube. So, I am planning to rebuild it.
I am running 33” tires. 4.0, 5 speed. 98k miles. I see no issue with the rear axle.
I think I have the budget for 3 options.
1. Rebuild front stock 3.73
2. Rebuild front with 3.73 and add lunchbox locker
3. Rebuild front with 4.11 or 4.56 and re-gear the rear to match
Which do I choose? Or is there a 4th option I should consider? (Trying to stay under 1k)
Since you have a Dana 30 up front, the cheapest option would probably be to get a used Dana 30 out of another TJ with 3.73 gears.
They are pretty common and around here you can easily find a complete one for $100-200.
Maybe I am looking in the wrong place, but the ones I am seeing are in the $800 to $1000 range. And the history is usually sketchy.
