K good to knowThat’s an accumulator. You cannot mount that in a horizontal position because the one of the lines has a standpipe on it.
Except you would starve the compressor of oil at that point. Your compressor won’t be happyIt does seem good to know but now I have to ask,
Since the AC works while going up, down and around hills, what if that accumulator was horizontal with the outlet tube inside high? The oil and liquid refrigerant could still drop to the bottom from the inlet tube and the vapor refrigerant could still float to the top.
EDIT:
Of course, as soon as I hit "post reply" I realized that another accumulator probably needs to be cut open so we would know which "horizontal" would look like my rotated picture if it even would work.
EDIT:
See that little orifice at the bottom of the u-tube. That lets small amounts of oil that has accumulated at the bottom to be drawn out the suction tube to lubricate the a/c compressor.It does seem good to know but now I have to ask,
EDIT:
