Can I put 31 inch x 10.5 BF Goodrich KO2 tires on stock 15 inch stock steel wheels without spacers? If I do this, will it rub?
Some pics in this thread, although not specifically of the rear spring perch. That thread was with 31" Falken Wildpeak AT tires.Anyone have a photo of this setup at the rear upper spring perches?
I can barely fit two fingers between the upper spring perch and the tire with my current setup. Must be really close with tires that are one inch+ wider. Just curious to see how close it would be.
This pic is the best I have. This is a 31x10.50r15 tire on a 15x8 Ravine rim with 5.5" backspacing. The axle is at full flex on the driver's side.Anyone have pics of this spot with 31x10.50s on stock 15x7 steel wheels?
