Can I replace dual mass flywheel with a regular clutch?
Trisha
Maine
So I have an 06TJ with a 2.4 and I blew the clutch and now I discover that it has a DMF and I'm wondering if I can replace it with a regular clutch or do I have to install a replacement DMF
The vast majority of the time all the fw needs is some scuffing with emory cloth. The same info is also described in the factory service manual.
Unless you are seeing real damage on the flywheel like grooves and gouges just clean up the surface to break up any glazing. Do what Rob5589 suggests and that should be enough. 👍
