Okay thanks, so it won’t matter that it’s a high pinion?It would be 1000% easier and cheaper to swap a Dana 30 from a TJ or a HPD30 from an XJ. The YJs are leaf spring and will need all new bracketry. Both the TJ and XJ axles are bolt in and are readily available.
okay, thanks for the advice!It would be 1000% easier and cheaper to swap a Dana 30 from a TJ or a HPD30 from an XJ. The YJs are leaf spring and will need all new bracketry. Both the TJ and XJ axles are bolt in and are readily available.
Okay thanks for the input!Plus you would have to deal with the axle disconnect.
Stick with a TJ or XJ Dana 30.
High pinion is actually better for the driveline. Keeps your driveshafts above the axle tubes. Which means more clearance in the rocks. That and the fact it’s a stronger ring and pinion setup being high pinion.Okay thanks, so it won’t matter that it’s a high pinion?
YJ’s use high pinion reverse cut gears in their Dana 30’s. The TJ uses a low pinion cut gear, so not they will not swap over housing to housing.Could he just swap in the ring and pinion from the YJ axle into his TJ axle already in the Jeep? That could be the easy solution.
Yup. Their only real downfall is the axle disconnect. And honestly, it’s not really an issue. A longer one peice shaft allows for a bit more flex and torsional strength. But an XJ or TJ 1 peice shaft can be slid in seamlessly. Just have to block off the axle disconnect with a simple plate.Wow! Never knew the YJ was a high pinion. You would think after all these years of working on 'em I would have delt with at least 1 front axle.
None of the 5 I owned were high pinion, it must be a Canadian thing or maybe one of those fancy Australian rigs...Wow! Never knew the YJ was a high pinion. You would think after all these years of working on 'em I would have delt with at least 1 front axle.
Very stange that you had a YJ with a low pinion 30. Maybe only the American versions had them. Very odd.None of the 5 I owned were high pinion, it must be a Canadian thing or maybe one of those fancy Australian rigs...
Exactly.Yeah those vacuum disconnect hp30s are everywhere when you're looking for a non-disconnect axle
