I’ve had my 2003 TJ Rubi for about 3 years now. I’ve just now started working on upgrading, after developing death wobble.
it came with an OME 2+ inch lift, plus some spacers.
So I went through the steering and brakes and replaced power steering hoses while it was up. Death wobble is completely gone. Using how to from this forum I aligned it and it tracks straight and true.
However, I can’t get the brakes to lock up. It stops straight, and strong. The pedal is firm. Not rock hard, but firm and not spongy.
The brake upgrade was a new Dorman M/C, all 4 discs and calipers and SS lines to each corner.
I bench bled the M/C before installing it. There is zero air in the system, rebled twice, both pressure and vacuum. There are no discernible leaks anywhere. Seated the pads per the manufacturers instructions. Although I barely smelled them heating up. Ambient temps were in the low 30s
I have 32s on 16” wheels. Could they have enough mass to prevent lockup?
It does not have ABS. Right now with some snow and ice the “softer” brakes aren’t a problem.
Any advice or help is greatly appreciated.
sorry for the long first post.
