…..other than compression lol.
If anyone has read my previous posts on my son’s jeep. We had a cracked head which led to coolant in the oil.
- I bought a remanned head, from a local shop that had been resurfaced, 3 angle valve job, pressure tested, completely redone. Cleaned the engine down, put the new gasket on,
Installed the new head, torqued it down per spec. Installed the rockers from the old head, assembled the whole rest of the engine, new plugs. Blah blah blah.
Turned it over to start, of course after putting fresh oil and fresh coolant in. And it spins over like it has no plugs in it at all. Checked compression and nothing in any of the 4 cylinders.
The head. casting I had was 117, the casting I bought is 403 in case that makes a difference.
I could understand one cylinder but not all 4.
