Recently I’ve noticed that at the higher temps outside 90s to 100 degrees F, my engine has been running roughly. In the past I’ve had to do the fix where you add insulation around one of the injectors due to heat. I’m curious if this heat could be the culprit behind my misfire and how I could go about rectifying the issue. Wether it be replacing the injectors or adding insulation around all of them.
Extra details to add:I recently replaced the TPS with an NGK sensor, and I have not replaced my spark plugs in a while.
