Have power loss at highway speeds, has a miss and throwing a code for miss on cylinder 6
Changed the plugs and have checked the temp on all of the cats - none are too hot or cold
All injectors sounds the same and have one of the stupid fuel rails (2004) without the valve to check the fuel pressure. Only Chrysler......
Was going to try coils next
My question: the Mopar coil rail is WAY more expensive than the NGK (which generally makes good products). Is it necessary/worth it?
Thank you
Thank you
