Anyone find a good option for a coil suspension setup on a trailer? Not finding much in the US or a build sheet to fabricate them.
You have been doing a lot of the same research as I have been lately. I’m building my frame currently and went with the 2200# 4” lifted version as well. Also got a lock n roll hitch set upPersonally, I would go with a trailing arm suspension, like the Timbren Axle-less. If you use coils, you'll need a trailing arm or some other suspension anyways, so it's easiest to just put the spring right on the trailing arm.
In addition, the axle-less has much better ground clearance than coils, leafs, or a torsion axle. (You can't even get that clearance on the TJ without portal axles.)
Depending on your weight capacity needed, they have units that will match the wheel pattern of the TJ. I believe the 2000HD, 2200, and 3500 lbs (but not the 3500HD) all use 3500 lbs hubs, which match the 5x4.5 wheel pattern of the TJ.
The 2200 lbs model is an interesting one, as it has a much longer trailing arm, giving it a lot of suspension travel and a soft ride.
The HD models are simply higher rated setups that are derated for use with softer springs and in more abusive conditions. For example, the 2000HD is a 3500 lbs model with a softer spring. The 2200 is a 3500 lbs model with a longer torsion arm. The 3500HD is a 5200 with a softer spring.
https://timbren.com/c-1389196-products-axle-less-trailer-suspension.html
You can also get them with lift or drop so you can height match the trailer to the TJ. And you can also get different stick out lengths, so you can run 35×12.5 (or larger) tires without issues.
Ultimately, I would like to build one using the 2200 with 4" lift. Running 35s, it would be at the same loaded frame height as the TJ with 35s and 5" of lift. With 3500 lbs hubs, I can run a good set of brakes with a separate parking brake, and use the exact same wheels and tires on both the TJ and the trailer.
I agree, a simple leaf spring setup is almost maintenance free and stupid simple. Just add shocks and have the trailer tires balanced and the trailer will ride nice and smooth.For a trailer I'd stick with a simple leaf spring suspension.
The other type of axle you might look into is called a torsion axle. It has a center beam like a beam axle, but it’s technically an independent suspension, as each end is sprung separately. It supposedly gets a better ride than a leaf spring, and is easier to install. It is more expensive than leafs, but cheaper than the axle-less.
Ground clearance of a torsion axle is comparable to a beam axle on leafs.
Personally I would go straight to the axle-less and skip the torsion axle if I wanted something more than leafs. However, it is worth a look.
If you would, lemme know how you do that. I may want to do the same to my M416.I have a simple dexter 3500 axle I ordered custom, simple spring over.
my trailer is a M416 and loaded down weighs 1200 lbs. it works great. I drag it into things that would rip apart normal trailers. I do t even run shocks, keep the tires low for the weight and it does everything I want it to. Still run the pintle hitch but plan to remake the tongue and do a lock and roll. WAY quieter.
Neighbor has a tear drop with the timbren axleless setup. He likes it but they don’t use it so hard to really say it’s the best.
I do like that most of the Aussie builders use it though, so honestly it must be pretty good stuff. But I think overkill for my little off-road trailer. And my axle was like $135 bucks, shipped.
