That’s my plan. Just seeing if any members are parting out a Jeep and could ship that part to me. Not got free of course tho lolif that's the power from up front that's part a of harness, not just that lead, IIRC. find a local part out or junk yard and see if they'll let you snip it off. then just tie it into your wires.
Worse case, you could get a set of molecular connectors and replace both, the tank and harness end.That’s my plan. Just seeing if any members are parting out a Jeep and could ship that part to me. Not got free of course tho lol
I thought about that. Might have to do it if I don’t find anythingWorse case, you could get a set of molecular connectors and replace both, the tank and harness end.
what connectors should I get and what ones will work?Only 4 wires just get some connectors and do it
If you have the pigtail text me. Number is 1(262)-366-8166.If you do replace the connector make sure it's rated for the amps.
I have a spare pigtail that will work for you but I don't know exactly where I left it. If you'd like, I can let you know once I run across it.
What amps wouldSomething like this.. https://www.amazon.com/dp/B07QFW8X9Z/?tag=wranglerorg-20
what amps does it call for? Does anyone know that?If you do replace the connector make sure it's rated for the amps.
I am in need if they didn’t take it.I found it. Lmk if you'd still like it.
Thank you! It’s impossible to find.I still have it. I'll PM you after I find it again.
That would be awesome. I believe the fuel pump harness is the same?I have a 99 engine harness. I could snip that part.
