Looks like I may be having some ground issues potentially causing electrolysis. Could be a bad heater core causing the smell I’m getting in vents. I’ve already checked the resistor (new) and the fan (new) as well as there’s no leaves or debris under the cowl. There appears to be one ground wire from the hood to the body that I need to replace. But I really don’t think that’s causing the issue. Here are a pictures of the body to engine, ground strap and broken hood ground strap. The body to engine strap is green, but pulling on it it’s still very strong connection on both sides. I’m good with a lot of mechanical things, but electrical is not my area of expertise. I had to replace the radiator recently when I was doing a full flush because the petcock and the other one continued to leak. The picture shows the radiator along with the new screws attaching it to the frame.
